CrazyTalk Animator Now Works With Mac Virtual Machines
https://forum.reallusion.com/Topic81262.aspx
Print Topic | Close Window
By Peter (RL) - 15 Years Ago
With the release of CrazyTalk Animator v1.11 you can now use CTA on your Macs using Virtual Machines. Both VMware Fusion and Parallels Desktop can now be used to run CTA on your Macs.
Another new addition for those using virtual machines is a new option added on the Export Panel to allow for Supersampling. This will help smooth out the anti alias feature which is not fully supported on virtual machines.
To get this latest update, just login to your Account and click Bonus & Upgrade for your version of CrazyTalk Animator. Alternatively you can use LiveUpdate to download.
By Emily March - 15 Years Ago
I'm trying to use Crazy Talk Animator with Windows 7 in Parallels on a Mac. I installed version 1.11.1614.1. The program loads, then opens briefly before disappearing. Any advice? The other problem I'm having since installing Windows 7 on a PC is that my Cepstral voices won't work in Animator, but they do work in Crazy Talk. Any fix for that?
Thanks!
Hi Emily
I would advise contacting Tech Support using the link below. They will be able to look at your system and the probable causes of the issues you are having.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Please supply all the requested information about your system for the quickest resolution.
Thanks.
Thank you, Peter.
By gadav11 - 15 Years Ago
I tried installing crazytalk pro animator v6.2 on my Imac running parallels windows XP and message popped up: cannot run on virtual machine. Any advice will be appreciated.
gadav11 (5/31/2011)
Are you referring to CrazyTalk 6.2 Pro or CrazyTalk Animator? They are two different products.
If you are using CrazyTalk Animator then please make sure you are using version 1.1 which allows CTA to work with virtual machine software like Parallels.
If you have the latest version of CTA or are using CrazyTalk 6.2 Pro and still having problems then please contact Reallusion Support using the link below. They will help you diagnose the problem.
Thanks.
By HD13 - 14 Years Ago
Thanks for this, I was just pondering options how to use it...
I read in another posting that iclone will not support mac in near future (quite ironic given the product name ;)) and that it only runs with bootcamp and windows. Would be so great if it also could be used like Animator, is it due to technical issues with graphics and such that it is not possible or is there hope for mac users?
By Peter (RL) - 14 Years Ago
unique (1/28/2012)
Can you supply a link to where you saw this statement. Thanks
https://forum.reallusion.com/Topic90136-281-1.aspx#bm108037
https://forum.reallusion.com/Topic12599-13-1.aspx
unique (2/3/2012)
One of the posts you reference is from 2008 so the situation is different now to what it was then. The other is from another forum user and not an official statement from Reallusion.
To the best of my knowledge Mac support is still planned for future editions. :)
By Vrancken Media - 14 Years Ago
I love Crazy Talk Animator an iClone, but I work with Mac. Can I use also VirtualBox VM or just Parallels and VMWare?
s.vrancken (11/19/2012)
Only Parallels and VMware have been tested with CrazyTalk Animator. iClone5 does not support virtual machine software at all.
By cmaseattle - 13 Years Ago
We have an issue running it through Parallels. The error message says it CTA initialization failed. We haven't heard back from support yet.
We meet the system requirements and have run all the updates we could on this fresh install (Windows7, CTA 1.2, Parallels 8).
Computer is a recent MacPro 2xQuad 3Ghz
ATI Radeon X1900 512VRAM
9GB RAM
OS X 10.6.8
Any thoughts ?
By Peter (RL) - 13 Years Ago
cmaseattle (2/22/2013)
9GB RAM
OS X 10.6.8
Any thoughts ?
The ATI Radeon X1900 is quite an old graphic card and is not on our recommended list of graphics cards for CTA. Then on top of this you are using virtual machine software so that only exacerbates the situation when it comes to graphics problems.
http://www.reallusion.com/crazytalk/animator/animator_requirements.aspx
Hopefully support will be able to advise you further but the graphic card is likely the problem here.
