Sound FX and Background Music
https://forum.reallusion.com/Topic80279.aspx
Print Topic | Close Window
By jaakay - 15 Years Ago
Hi
How do you edit the length of a sound effect in CTA on the timeline?
I have imported the sound effect of walking on a wooden floor, but I can workout how to make the sound stop when the character stops walking.
I have managed to find the sound track in the timeline, but I don't seem to be able to lengthen or shorten it or even add a keyframe or two to lower or increase the sound at any given position.
Thanks for your help in advance.
By Peter (RL) - 15 Years Ago
CrazyTalk Animator only has basic audio editing features so it will be best to have your background music, sound effects prepared before you start your project.
You should prepare all your sound files first in an audio editor before adding them onto the CTA timeline. If you don't have an audio editor you can use the free program Audacity for this.
Once you add a sound file to the timeline you can double click it to open the Modify panel. From here you can add Fade in and Fade out points for your  music and sound effects. See HERE for more on this.
You can also drag them to the correct location (frame position) or add mutiple copies shoud you wish. You can right click on the timeline sound fx track and choose Import to do this.
