importing video
https://forum.reallusion.com/Topic79986.aspx
Print Topic | Close Window
By chiplatham - 15 Years Ago
i cant figure out how to inport green screen footage from pinnacle studio. the popvideo program will not import my file type. the program also seems to be stuck on demo. how to a start a new screen? i hit "new project'
By Peter (RL) - 15 Years Ago
Hi..
Firstly if you were previously using the trial version of popVideo Converter then you will need to uninstall this version and then install your full purchased version.
When it comes to file types accepted by popVideo Converter these are described HERE. If you use formats like AVI or WMV then you should have no problems. Of course if you are using a codec for AVI like DivX or XVid then you shoud ensure these codecs are installed and working correctly first. You can also try uncompressed AVI which should work fine too.
It is often best to play around with different video formats and find the one that works best for your requirements regarding quality output size etc. :)
sorry...i am trying to import video into i clone, not trying to import footage into pop video. how do i bring regular video (ie already keyed out) into iclone?
By Paumanok West - 15 Years Ago
chiplatham (4/6/2011)
The video image goes into the Diffuse channel of the object to be textured (you probably want a Bilboard). A second alpha-only video goes into the Opacity channel.
