jaakay (3/23/2011)
I have 2 questions:
1. When I was trying to do lipsyncing in CTA I found that I was not able to fine tune the lipsyncing in the same way as when using CT6, ie., going into the timeline and being able to click on syllables and be able to exaggerate them. I was actually lipsyncing an accapella so needed to access the mouth shapes as you can in CT6. I could not find this option in CTA. Is it actually there or do I need to have CT6 to create more precise lipsyncing and then import that file into CTA?Please take a look at the reply I gave below. This covered the same question and should help.
https://forum.reallusion.com/Topic79289-254-1.aspx
2. Is there a workflow for using the Power Tool Characters (human and comic) to amend/customise them to create different clothing to create new characters. I know that you can change colours (comic characters) but I want to be able to make more changes than just colour to create original characters. Are there any templates that can be used in Photoshop/Flash/Illustrator so that you can create original content in the right sizes that can be used to replace uppers, lowers and sprites (depending on whether they are human or comic characters).
Vector based characters like those in the Power Tools are made up of 16 parts (see below) so you will need to replace each part with your own custom sprites in order to create a new character.
If you haven't seen it yet I would take a look at a new tutorial video we have available (link below). This shows some great tips in replacing the body parts of an existing character with those of an entirely new character. This should help you understand the principles involved. :)
https://forum.reallusion.com/Topic78782-254-1.aspx
