Cloth and Character compatibility
https://forum.reallusion.com/Topic78610.aspx
Print Topic | Close Window
By Gentlegiant783 - 15 Years Ago
Im useing Iclone 4.3,  Im trying to figure out if the G3 Clone Cloth Pack and/or the G3 New Look will be compatible with the characters Ive created,  Im trying to find out wether or not there will be compatibility issues before I spend money
By Peter (RL) - 15 Years Ago
Hi..
The original G3 CloneCloth and the New Look CloneCloth are both fully compatible with all characters created using G3 avatars. Obviously if your characters were created using G2 avatars then you won't be able to mix and match parts apart from the heads. These can be interchanged between any generation of avatars.
One small issue you may find is that the head sizes of the New Look CloneCloth avatars are smaller than the original G3 avatars, but this can be overcome by resizing the head to get a better fit.
Thankyou.
Is there a way to save a head after I have refined it?
You certainly can. :)
Just switch to Head - Faces and then click the Add button at the bottom of Content Manager.
Thankyou very much, most helpful
