Double install?
https://forum.reallusion.com/Topic75190.aspx
Print Topic | Close Window
By wjs_pdi - 15 Years Ago
Is there any potential conflict with installing CTA Pro and Crazy Talk 6 on the same computer?
By Peter (RL) - 15 Years Ago
No none at all. You can safely have both products installed on the same PC. :)
Thank you.
By yaRincewind - 15 Years Ago
Another question please:
If I buy repacked content for CTA, can I use it under CT, or should I buy CT content and repack for CTA?
Especially if I whant to use facial animation of CT in iClone?
yaRincewind (1/19/2011)
The motion clips included in the Facial Animation Clips and Natural Facial Performance packs can be used in either title (with slight differences) but will need to be manually copied from one to the other depending which pack you purchase.
The best option will be to buy the pack for the version of CrazyTalk you will use the most and then manually copy over the files to the other title. There is a explanation of the manual copying process HERE.
