Save initial pose?
https://forum.reallusion.com/Topic73851.aspx
Print Topic | Close Window
By namunger - 14 Years Ago
Is it possible to save the initial pose for a character? Say, for instance, I've modified a base character into an infant, and I want to always have it start out in a crawling position. So far, when I save the character, it always reverts to the default standing pose, and I have to move it whenever I add the character to the scene.
By planetstardragon - 14 Years Ago
what i usually do , is when the character is in a pose that I like, I'll right click the character and "remove all animation" , that will remove all animation from the character without resetting the pose, thus freeze it.... from there you can simply make the whole scene 1 frame ( else it will save a motion file of the entire scene even though it's not moving, and you really just want 1 frame ) add that motion to your library, once you saved that, call back your scene....and import the 1 frame motion you made as a pose, the character will stay in that position until you alter it .....remember to add 1 keyframe right before you add a new motion else Iclone will try to fill in the blanks with tweening, and maybe you just want the character still till the exact place you place the new motion.
Not sure if this answered your question, but i had fun answering anyways lol :)
Cheers.
Well, it's a good work-around, at least! Much faster than re-posing every time.
Thanks for the tip!
