Errors
https://forum.reallusion.com/Topic69729.aspx
Print Topic | Close Window
By pbi - 16 Years Ago
I have this errors:
1) when Crazy Talk animator starts
2) when i select: face creator - import image - next button, on image processing windows
By Sen - 16 Years Ago
Hi ,
look this thread for live update ;).
Sen (11/30/2010)
Hi ,
Thanks, the first problem is solved but the second remains.
By Peter (RL) - 16 Years Ago
Hi pbi,
Sadly I 'am not able to translate the error message into English.
Please contact Reallusion Support using the link below. They should be able to help you with this issue. Please explain your problem in English if at all possible.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
[quote]Peter (RL) (11/30/2010)
Hi pbi,
http://www.reallusion.com/CustomerSupport/User/QForm.aspx[/quote]
Is the classic Windows error message when an application crashes,
"There was an error in CTApp.exe. The application will be closed ..."
I have already contacted the RealIllusion support.
Thank.
The error is resolved. It was caused by the graphics card in my PC, a ATI Radeon 9200.
The following lists the steps to solve the problem suggested by the developement team:
REAL Illusion:
We provide a solution by editing windows registry for you to solved this issue
Follwo the steps below to edit the Windows Registry for CrazyTalk Animator
1) Click Start | Run | type Regedit.
2) Find the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Reallusion\CrazyTalk Animaotr \1.0\
3) And then you will find the key of Use AFT Fit
4) Double click to open it
5) Enter 0
6) Press OK
7)Open CrazyTalk Animator again
