Can I add popvideo to PowerPoint 2010?
https://forum.reallusion.com/Topic66719.aspx
Print Topic | Close Window
By narf2n - 16 Years Ago
Can I add some for of video with my avatar acting on a transparent background and add it to PowerPoint 2010 ?
I don't want to import my pptx to flash / air or what ever - just want to add media files created using iclone / Crazy Talk / Widget Cast with their transparent background to my PowerPoint slides...
is it possible ?
By Peter (RL) - 16 Years Ago
Powerpoint won't be able to open .popvideo format files directly but it is possible if you export in Sequence Image format (32bit). You will need to compile the exported images into video format first before inserting into Powerpoint but this is easily done in most video editors.
By michel.gervais - 10 Years Ago
I don't see the added value of using Popvideo if it can't export transparent videos to be imported to PowerPoint, Captivate, or any Multimedia platform for that matter. Saving in ping images and re importing in a video editor is time consuming considering that you have to add the sound track separately in the video editing software after it was all done in Crazytalk animator or Iclone.
If Popvideo's only purpose is just to  chroma-key two video tracks, then all decent video editing software are capable to do that.
In my opinion, the capacity of exporting transparent flash or mp4 files to be used in multimedia software should have been addressed be Reallusion a while ago.
Michel
