Hi again,I have checked with Support and they had already replied to your Support request. In case you are still experiencing problems logging into your account I include their response below.
From Reallusion Support
Regarding to your first question, as Montage vol2 and virtual Studio vol2 are DRM protected content, so it needs to verify your iClone4 and the transaction record via internet when installing. So we suggest that you connect to the internet while your install DRM content.
We checked the error code 99 message and we found that you should Update your iClone version.
For the content of 3D VFX - Virtual Studio Vol. 2 and 3D VFX - Motion Montage Vol. 2 , it should be installed in iClone v4.12 or above. Please Make sure that you''ve updated to iClone v4.12 or above.
You can go to "?" > "About iClone" to have a check.
If not , you could follow below steps to download the patch and then update the version to v4.3
1) Login to your member account: http://www.reallusion.com/member/program/memberreg.asp
2) Click "Bonus & Upgrade" to on the right-hand side of iClone4 Pro.
3) You could find Patch downloads, iClone 4.1 Patch > iClone 4.3 Patch
If your problem continues Please follow the below steps to export your registry keys to us.
1) Click Start, and then click Run.
2) In the Open box, type regedit, and then click OK
3) Go to "HKEY_LOCAL_MACHINE\SOFTWARE\Reallusion",
4) On the File menu, click Export.
5) In the Save in box, select a location where you want to save the Registration Entries (.reg)
6) In the File name box, type a file name, and then click Save.
7) Attach this file to us.
If your operating system is 64 bit, the entry for Reallusion would be the following location.
"HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Reallusion"
If you have any further queries, please do not hesitate to contact us.
