Link Cloth prop with dynamics enabled to a characters hand
https://forum.reallusion.com/Topic557653.aspx
Print Topic | Close Window
By gerd_335092 - Last Year
How would you set up the following scene?
2 characters stand next to each other at a distance and should each hold a banner with one hand.
The banner should be dynamic. This means, for example, that it folds or waves when one of the hands is moved upwards.
Unfortunately, I can't get it to work.
I've already tried using cloth prop as the banner and link to and also attach to one hand. I have also switched off gravity. Unfortunately without the desired success.https://forum.reallusion.com/uploads/images/6c8b044d-462f-4d3a-99da-39c3.jpg
By Rampa - Last Year
There are "pinned" cloth props that can have each pin linked to a different object or character. See the pinned cloth section on this page:
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/57-Physics/Using_Soft_Body_from_the_Library.htm
PERFECT...exactly what i need. Thanks so much for your quick help :)
