Que renders
https://forum.reallusion.com/Topic557534.aspx
Print Topic | Close Window
By mgr0704 - Last Year
Is it possible to queue multiple renders in iClone 8?
By animagic - Last Year
mgr0704 (11/10/2024)
There is a Python plugin: https://marketplace.reallusion.com/batch-render-folder.
Unfortunately, it is only for iClone 7. It would be nice if it were updated for iClone 8.
Thanks
By 4u2ges - Last Year
Here is a replacement main.py for the plugin to work under IC8.
Note: Plugin will render the entire timeline (All keyframes) for all projects in batch folder and will disregard the Export Range if it's set within the Render settings.
Make sure to set the correct Timeline length in "End Frames" under Project settings for each project.
