Insanely low FPS even on minimal quality...
https://forum.reallusion.com/Topic557469.aspx
Print Topic | Close Window
By ender570 - 2 Years Ago
Since the last update, my FPS in both Iclone and CC4 has been in the single digits even when running it at the minimal quality settings. Anyone else seeing this?
I run a 4090, so it's not a hardware issue.
Edit:
It seems that the application is only using my RAM and CPU for some reason and not utilizing the GPU at all
Anyone see this before? I don't see an option to select a render device anywhere
Edit 2:
Okay, it seems that it is using the GPU afterall.
The problem seems to be something to do with Gsync. Using the Nvidia Control Panel, I disabled Gsync for Character Creator only through the Program Settings and this seems to have fixed the problem.
I figured I would share the issue here for anyone else that might have it in the future!
By Peter (RL) - 2 Years Ago
Thanks for sharing your findings. This will help others encountering the same performance issues. :)
