Schellicon (10/29/2024)
ok don`t use this button ... not working :(
i workarround it with the color correction in the material panel
That is the correct approach. The skin color button in the plugin is good for correction, if the automatic match was off between head and skin. Note that you can also multi-select all the body materials at once in the modify panel, and adjust the color of all of simultaneously. Use Shift-click or Ctrl-click to multi-select.
