iClone 8.5 (8.5.3330.1) crashes when removing full expression
https://forum.reallusion.com/Topic556951.aspx
Print Topic | Close Window
By Zimon - 2 Years Ago
iClone 8 Version: 8.5 (8.5.3330.1)
Following the removing full expression Reallusion guide, provokes a crash and project restoration.
In order to reproduce it I create a Motion Live expression clip (using iPhone Live Face), then I try to reset the expression with Face Puppet.
SUGGESTION: It would be nice to have a key shortcut instead of must following a guide, to simply reset character expression. Or even better, you could make optional to automatically reset face expressions at the end of a face clip (puppet or motion live).
Guide:
https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/7.9/08-Animation/Facial-Animation/Removing-Facial-Expressions.htm
By Peter (RL) - 2 Years Ago
Thank you for reporting the issue. As well as posting here, please can you report all suspected issues and bugs in our Feedback Tracker. The tracker is monitored directly by the iClone team who will investigate the issue and give you a status update. The tracker is the best way to get issues looked into and fixed.
To use the Feedback Tracker, please click the link below.
Thanks.
Sure, done.
