By Darren01 - Last Year
I found a scene containing multiple objects that I would like to import into iClone/CC I've figure out how to import the scene from either the obj or FBX file into CC. However textures haven't been applied.
There is a mtl file included with the scene. Is there a way that CC can decode the mtl file and it will automatically apply the textures to the props in the scene, or will I need to manually texture each prop manually myself ?
Thanks for any assistance.
By Peter (RL) - Last Year
Hi Darren
If you open the mtl file in Notepad you should be able to see where the textures are expected to be found (folder, filename etc.).
If you then put the textures in the correct folder and the filenames match, then CC4 should be able to find them when you load the fbx or obj.
By ad.ramos - Last Year
I have a serious problem. It has happened to me multiple times. While I'm working with a character. I create accessories in independent programs. When I want to import them to place them in CC4. Using menu create. The program collapses and closes. I have reinstalled the program. The error is corrected. But in time it happens again. I'm quite sad and angry after spending so much time/money and these problems occurring. What solution is there?
