Prop to the head of the actor
https://forum.reallusion.com/Topic556145.aspx
Print Topic | Close Window
By Lynn_w - Last Year
Hi,
Beginner question.
I created a head band prop with bones, saved it and try to add to an existing actor in composer mode.
I got it position on the head in composer mode, but it is not under the head group layer, so I can't edit in 360 head creator for the prop.
How should I adjust it to the head group? so it will be part of the 360 rotation too.
Another question is when I add the accessory in the stage mode on the actor, the attach button is greyed out, why is that so?
Thank you.
By Peter (RL) - Last Year
Hi...
Please take a look at the tutorial below. This explains how to add props to your character and make them accessories.
https://courses.reallusion.com/home/cartoon-animator/character?v=cartoon-animator-4-tutorial-attaching-accessories-to-a-character
Hi Peter,
Thank you for your reply.
I manage to link props in the stage mode.
I can add the bangs in the composer mode, but how do I get it under the head group layer, so I can do 360 head turn with the bangs as well? like in the screenshot, I can't transform the bangs as it is not under the group.
