The problem with importing SVG from CorelDRAW
https://forum.reallusion.com/Topic555620.aspx
Print Topic | Close Window
By azbuss - 2 Years Ago
Hello! Updated Cartoon Animator 5 to the new version 5.3.3226.1. When importing SVG from CorelDRAW, the character file is obtained in one layer. Reinstalled the old 5.0 version - the SVG file is imported as expected - in layers. After upgrading to the new version of Cartoon Animator 5, the same story: a character in one layer. I checked the SVG import from AI - the import went fine. I would like to ask the developers to deal with this problem as soon as possible. Thanks!
By wires - 2 Years Ago
The only direct way to contact the developers regarding such issues is to use the Feedback tracker as posts there are read daily by the responsible team members. Use the link below.
https://www.reallusion.com/FeedBackTracker
Спасибо !
By Peter (RL) - 2 Years Ago
UPDATE:
This issue should be fixed in the latest update. Please update from the Reallusion Hub if you haven't already. Thanks.
