Many missing morph sliders in CC4 trial version
https://forum.reallusion.com/Topic554454.aspx
Print Topic | Close Window
By danpater10 - 2 Years Ago
There are many morph sliders that I want to test out such as "eye roundness" and "monolid" but can't find. They aren't under the Modify section or in the Content Manager section. Is there some way to download them, or can I not use them in the trial version?
Thanks
By Peter (RL) - 2 Years Ago
Have you installed all the packs in the "Free Resources " section of Content Manager?
Yes. All the morphs from that section are downloaded. They do not include many of the ones I'm looking for.
Any solutions?
If you have installed all the Free Resource packs then you will have everything that comes included with CC4.
However, you can add further morphs through packs like the Ultimate Morphs pack and also additional morphs are available with the Headshot Plug-in. In addition, further morphs can be added with packs from developers other than Reallusion.
You mention two specific eye morphs which are not included in the free resources. So where did you see these two morphs originally?
By johnwarndt52 - 2 Years Ago
The CC4 sliders won't let you change the angle of the eyebrow.
Or turn the tip of the nose up or down.
Or change the length of the legs.
Or the thickness of the shoulder...
Or do ANYTHING with the arms, so far as I can see.
All of those things were permitted with CC3, but not with v4.
johnwarndt52 (10/14/2024)
There is a leg length morph slider and arm sliders that come with CC4 so it's possible you haven't installed all the free resources as mentioned previously? CC4 also has the same embedded morphs as CC3 so is it possible you had additional morph packs installed in CC3 that you haven't yet installed in CC4?
Peter,
Apparently I neglected to install a couple components of those packs, but when I did, the missing components appeared on the morph sliders. So everything seems to be working OK now.  Thank you very much!  There are so many hair styles, wardrobe items and props that I need for my project, but they were just impossible to use in ic7 and cc3.
I still have some questions, but I'll open a support ticket for those because they don't apply to this topic.
John
