GOZ PLUS SUBDIV
https://forum.reallusion.com/Topic554153.aspx
Print Topic | Close Window
By Siverse - 2 Years Ago
hI THE goz pLUS SUBDIV WON'T SUBDIVIDE THE BODY IT IS GREYED OUT FOR SOME REASON, CAN'T WORK IT OUT. PLEASEC AN SOMEONE HELP? THANKS
By TinaT - 2 Years Ago
It seems that you haven't enabled Divide, which is why the sDiv slider is greyed out.
Please try the following steps:
1. GoZ character.
2. In Zbrush,go to  Geometry > press" Divide".
https://forum.reallusion.com/uploads/images/d8b1b493-ba76-4d8a-bde6-6a17.png
3.Enable Layer Edit Mode
https://forum.reallusion.com/uploads/images/287e4177-77b7-4026-a594-d863.png
 (if you can't click on REC, try adjusting the CC_Detail slider back and forth).
https://forum.reallusion.com/uploads/images/69778f59-4cf3-4026-8c36-b583.gif
This should allow you to edit.
1. GoZ character.
