Support for 360 and 180 VR Rendering
https://forum.reallusion.com/Topic553930.aspx
Print Topic | Close Window
By Lord Ashes - 2 Years Ago
The current version of iClone has support for panoramic 360 rendering or Stereo rendering. Both of these techniques are used to render 3D content for FLAT projection similar to how you might see a 3D movie in the movie theater. In these formats the video has a normal, either being a very wide video (for panoramic videos) or having a left and right eye image side by side or above and below.
However, video for full VR emersion typically uses a equirectangular or fisheye layout. These formats are more conducive to wrapping the image around the user as opposed to projecting on a flat surface.
It would be nice if iClone supported rendering to such formats so that iClone could be used directly to render VR content without having to use a middle man software to apply the equirectangular or fisheye transformation.
Enclosed is an example image that is in the Fisheye format. As can be seen the snowboard is not straight because the image has been transformed.
By Peter (RL) - 2 Years Ago
Thank you for the feedback. Please do remember to post all wishful feature requests it in the Feedback Tracker. The tracker is monitored directly by the relevant product teams. In addition, it allows other users to support your request with the most requested suggestions normally getting priority.
To use the Feedback Tracker, please click the link below.
Thanks.
