I reported an issue with the curve editor
The agent replied with a suggestion for an IK selection in the motion layer panel, which had nothing to do with the curve editor problem as the solution they gave, was already engaged with the problem still present
When I responded pointing out that it took a month to get an ineffectual response, They doubled down responding with the same IK motion layer panel solution then closed the Issue, without ever properly investigating, let a lone solving the problem.
What's the point in having a feedback system if your operators ignore the issue or fail to investigate properly, and close the bug report out because they don't want to deal with it
