By alanyipchoy - Last Year
Hi Folks, I'm running into a wall when In try to retarget motions on a simple CAT Base Human target in 3DS Max 2024. I can get to the point in the online tutorial where I import and load the motion files and the bones configuration onto my target, but the animation does not play as it does in the tutorial. I would greatly appreciate some help on this, as it is going to be part of our Animation Curriculum this coming school year. Thanks to anyone who can shed some light on the issue, Alan Yip Choy
By Peter (RL) - Last Year
Hi Alan
I'm not sure which tutorial you are following but the one below takes you through the process and should resolve any issues you are having.
https://courses.reallusion.com/home/actorcore/3ds-max?v=actorcore-tutorial-for-3ds-max-retargeting-motions-for-cat-characters
Thanks for your response. As usual I discovered that the issue that I was having was due to operator error. Problem solved. Thanks once again.
