[Unity] [Actor Core] Animations don't work
https://forum.reallusion.com/Topic553397.aspx
Print Topic | Close Window
By piotrekr248 - 2 Years Ago
Hello,
I may have made some errors, but I believe I followed the same steps as before, which previously worked. Here are the steps I took:
1. I installed the package using the Unity package manager.
2. I selected and downloaded an actor and motions from the Actor Core site.
3. I imported all files into Unity.
4. I used the Reallusion Importer to import the FBX file.
5. I then built the materials and opened the Animations Preview tool.
6. I attached the idle animation to the tool.
7. Half of the character's body is underground.
I would appreciate your assistance in resolving this issue.
Thank you,
Piotr
By Peter (RL) - 2 Years Ago
Hi Piotr
Please check that you are following the steps shown in the tutorials below. These have been previously tested and explain how to successfully send ActorCore characters and motions to Unity.
https://courses.reallusion.com/home/actorcore/unity
However, if you find that there are steps in the tutorial that are no longer working for you, please can you log the issue in the Feedback Tracker and the dev team will investigate and update you there. Thanks.
By Victor.Soupday - 2 Years Ago
Make sure all your animation FBX files are imported as humanoid animation type:
https://forum.reallusion.com/uploads/images/5860618b-2e42-42b0-918f-eb25.jpg
Otherwise they won't play correctly on Humanoid characters.
Hi,
I tried to visit your website over the past few days, but it's all the time doesn't work :/
piotrekr248 (7/8/2024)
Hi,
Hi...
ActorCore is working fine for me (Microsoft Edge) and has not been offline. I'm not sure which browser you are using but please try clearing your browser cache and cookies and try again. Alternatively try a different browser if you have one.
