By hayang_039799 - 2 Years Ago
Hi there, I downloaded animation and dummy model from ActorCore Animation: https://actorcore.reallusion.com/3d-motion/free?asset=stand-to-sit_251123
And I followed the tutorial and use the define template provided by ActorCore: https://www.youtube.com/watch?v=lI98Mgqcxvg&t=1s
When I import he animation to the MotionBuilder, my animation's root is offset and leave the ground. How can I fix this? Should I enable any settings? It also happen when I use "Run to blast" animation.
If I check the animation curve, MotionBuilder's translation curve are different from Maya (Seems MotionBuilder exchange the Y and Z axis?):
Any suggestion will be helpful. Thank you
By Peter (RL) - 2 Years Ago
Hi...
If you have followed the tutorial carefully and the problem still persists, please can you report the issue in the Feedback Tracker. The tracker is monitored directly by the relevant product teams who will investigate the issue and then update you there. Thanks.
https://www.reallusion.com/FeedBackTracker/Product/ActorCore
I solved the issue by import the animation into Maya and save as a new file again with "Y up" axis setting selected even though it looks nothing changed in the Maya. After that the issue has gone.
Thanks
