GOZ Bug
https://forum.reallusion.com/Topic553076.aspx
Print Topic | Close Window
By RenanFabricio - 2 Years Ago
I was bridging my model to Zbrush and my zbrush crashed. Since then, im unnable to bridge and its giving me this error.
I've tried to reinstall Zbrush, CC4, Zbrush plugin inside zbrush and zbrush plugin inside CC4 and i'm unable to fix it.
What should i do ?
By Shinjitsu84 - 2 Years Ago
Same problem here, def need a solution for it soon...
https://forum.reallusion.com/uploads/images/78e1c347-5d03-4920-b0c4-74e7.png
So that was a new message for me too after upgrading to the latest CC4 but still on the older Zbrush 2022.0.1 - I had to upgrade to 2022.0.8 to be able to use GoZ again and yeah I got this error message.  You have to go into Zbrush itself inside its plugins folder to find this CC4 GoZ button.  Within that is a "reset" button that may unblock the transfer and let you continue working.
By fredericochem - 2 Years Ago
I am experiencing the same issue with GOZ PLUS, including a script error when trying to open ZBrush after the initial issue described. However, now it only shows the prompt to reset GOZ PLUS, even though I don't have its interface installed in ZBrush. It's been quite a headache. I really like Reallusion, but hasn't anyone addressed this issue yet? There must be other users facing the same problem.
By TinaT - 2 Years Ago
Please try restarting the plugin in ZBrush using the restart button located in the ZBrush plugin menu.
https://forum.reallusion.com/uploads/images/f24c603c-64c2-4a2c-9eeb-2e7a.png
See if this resolves the problem.
