By hohwproductions - 2 Years Ago
Hi all,
As you'll see below, shapekey adjustment is making the wrinkle maps turn black. I've not touched any materials, and I used the import plugin. Any suggestions?
Is it likely this is something from within CC4 (too many layers) or a Blender setting?
Thanks in advance!
By Victor.Soupday - 2 Years Ago
It's not missing textures because they would turn white.
The pattern of it suggests the problem is in one of the Std_Skin_Head_Wrinkle_DiffuseX.png maps. Maybe it hasn't exported properly?
You could try re-applying the wrinkle maps in CC4, see if that fixes it.
By Leodegrance - 2 Years Ago
I had a similar problem a few months back with version 2.02 of the plug-in. Subsequent update corrected the issue, but at the same time I re-exported the character, which also may have helped by saving the textures, re-exporting them to a new folder. I wonder though, is that character you're importing, is it a DAZ character sent via Transformer? Because, that's what my character was as well. Not sure if that might be a factor or not. Just throwing it out there. But, again, I re-exported the character with the updated version, I think it was version 2.03 or 2.04, and didn't have the problem again. Currently using 2.10 and haven't seen a recurrance of the problem with that iteration either.
I think I found the reason! I had too many Normal Maps in CC4 that seem to have been competing with one another. Stripping back (alot were unnecessary which I didn't realise), solved this issue.
