Motions exported to SketchFab
https://forum.reallusion.com/Topic551508.aspx
Print Topic | Close Window
By webdefender - 2 Years Ago
I am creating custom characters, rigging in Accurig, then exporting from Character Creator 4 straight to SketchFab. I can attach motions from Reallusion, but I think that violates the license if I either sell the rigged character or allow a free download. If I try instead to import a Miximo motion and save it as a motion file, for some reason it adds a lot of frames to the motion beyond the end of the movement. I guess it's because of the original project when I imported having more frames than the motion.
1. Am I missing something with the Miximo import?
2. Are there free motions that I can use from Reallusion even if I allow a free download or sell the model.
Thanks for any help
By Rampa - 2 Years Ago
You would need to use non-Reallusion motions if you are planning to sell, or otherwise distribute, motions with your custom characters. See here for using common motion types.
And check the EULA, of course.
https://www.reallusion.com/Content/EULA/EULA.htm
Thanks. The part I was missing was where the Mixamo motions were stored after importing. Using that motion file worked.
