Failed to load materialplus
https://forum.reallusion.com/Topic550897.aspx
Print Topic | Close Window
By evilgremlingames - 2 Years Ago
Using a cc4 neutral avatar and any xurge pack I cannot change the textures because I get an error.  I've noticed this is not unique to xurge and happens on many different packs on the content store.  https://forum.reallusion.com/uploads/images/576ad7d8-fd05-4a4f-b4ed-ac37.png
By radu_276037 - 2 Years Ago
I'm having the same issue.
By Peter (RL) - 2 Years Ago
The Xurge3D packs come with low resolution and high resolution versions.
So for example you will have an L version and an H version of the clothing as shown below.
AV_M_Cuirass_L_01.cccloth
AV_M_Cuirass_H_01.cccloth
So with that in mind you must apply the matching L or H materialplus file. You can't apply an H materialplus file to the L version cloth and vice versa.
By The Showroom - 2 Years Ago
I just purchased Business-M-00031 to use in CC4. I cannot apply any of the clothes to any characters. I can only open the premade characters. I get the same "Failed to load materialplus. File is invalid and/or unsupported item".
How do I use the clothes I purchsed?
tech_105584 (7/23/2024)
The Business-M-0031 is an ActorScan character not a clothing pack. This means as a Non-Standard character you can't change the clothes but you can use the suppled materialplus files to change the color of the clothing. Note: Only Standard Characters allow the swapping of clothes from your content library.
Please see below for an example of changing the color of the suit.
https://forum.reallusion.com/uploads/images/d70231ec-6923-4ddd-91cf-946e.png
