By danaisr76 - 2 Years Ago
How do I overcome hair colliding with the shoulders? I have a character with long hair, and it looks like the hair is "entering" into the shoulders. I would really appreciate it if there is a specific video that explains this and if you could direct me to it. I watched the videos available here: https://courses.reallusion.com/home/character-creator/hair-bread-and-eyebrow and didn't find an answer. Thank you very much
By Kalex - 2 Years Ago
Hey there, Sorry but for now I don't think there is a solution for this problem. I'm struggling too but it seems to be a recurring issue with soft cloth simulation when it comes to long hair. Even with original reallusion models the hair goes through the shoulders. Try to play around with the weightpaint map and the collision size... But I think it needs a big upgrade for next versions.
By 4u2ges - 2 Years Ago
Here are a few tips which will guaranty the success with long hair.
1. You have to utilize soft cloth physics (I guess this is obvious).
2. Collision shapes have to be distributed properly (this is also obvious). I have this article about dynamic collision shapes for advanced collision management. Hair must have an appropriate collision margin set. And remember that each Collision Shape also has collision margin set in the panel.
3. Hair must be above the body mesh and collision shapes before simulation starts. If hair goes through the body by default, you have to use morphs (if available) to raise it or edit hair mesh for that (Blender is a quickest way to achieve that).
4. Just a reminder to run/bake simulation in ByFrame mode and preferably start it in T-pose (or some other pose without head/neck/torso being bent).
5. Hair vertices should be 100% weighted to the head bone. A lot of hair come with part of the mesh skin weighted to the neck/shoulders/spine. This is a bad idea. It might not directly contribute to the penetration, but would cause hair distortion during simulation in most cases.
6. Now the main course - weight maps. Any part of the hair mesh which is expected to come in contact with collision shapes must have a pure white applied through the soft cloth physics map. A shade of gray coming in contact with a collision shape, would penetrate it regardless and a lot of hair out there disregard this. Below is a demonstration.
I run the same simulation with default weight map which comes with the hair, versus the one I tweaked. And here are screenshots of the baked sims for the same frame but different maps.
 And here is a difference where I recreated the gradient for the default map (for simulation above). As you may see the actual B/W gradient in only in the middle, but enough to give hair flexibility and smoothness. So the gradient is only to provide a smooth transition between static and dynamic parts of the hair. The bottom part (which comes in contact with collision shapes) is purely white allowing hair to bounce right off of collisions or glide.
Video where you can see a default vs tweaked weight maps influencing the hair. Camera is attached to the head of a dancing girl.
Hey that's actually a good point. Indeed weightmapping the hair 100% on the head could give better results. But a lot depends on the hair model and its complexity... At the moment there are still some imperfections in the shoulder area. What is the hair model you want to build ?
