SkinGen missing textures
https://forum.reallusion.com/Topic550539.aspx
Print Topic | Close Window
By mhaa87 - 2 Years Ago
In SkinGen there seems to be several missing textures, even though I just reinstalled the addon.
For example, for "Suntan Bikini" under "Blemish/4_Suntan/Realistic Human Skin" it fails to load these textures:
It looks like the files should have been in the folder "Reallusion Content\Reallusion Templates\Others\Skin Textures\SkinGen\4_Range\Suntan", with the other suntan textures. If I copy and rename other files to match the missing textures in that folder it will not give the error, it will correctly load those files. I can not find the files in another folder.
This is an issue with several SkinGen templates, not just this one.
By simoncharleshanna - 2 Years Ago
did you find a solution for this? im having this issue at the moment
By Peter (RL) - 2 Years Ago
simoncharleshanna (9/15/2024)
If the issue is with the Realistic Human Skin pack, please try uninstalling the pack in Content Manager and then reinstall. This normally resolves any missing texture problems.
However, if the issue persists, please contact Support using the link below. They will be able to advise you further.
