CC4 Activating appearance editor: 43 textures failed to load
https://forum.reallusion.com/Topic550094.aspx
Print Topic | Close Window
By davisjm4 - Last Year
Trying to age my character. when I activate the appearance editor, it fails to load textures and results in pure white texture for much of the character. In Outfits, with Actor selected, the activate appearance edit is grayed out.
 failing to load textures. My version is most up to date. Here's the video:
By Peter (RL) - Last Year
Hi...
First thing to check is that you have installed the content in the Free Resources section of Content Manager.
If you have all the free resources, then is it possible you have moved your content files and folders around since you installed CC4? I ask because there are clearly missing files and the file path shown in the error box looks a bit unusual. Moving content after installation will lead to numerous problems so should be avoided.
Overall the easiest solution may be to uninstall CC4 (and iClone 8 if you have that too) and then reinstall again, this time making sure you choose the correct drive and file paths you want for your content. Then when you install any content packs they will be installed in the correct file paths and it should resolve the missing files problem.
