By nikhilrath86 - Last Year
Hi! I had a question about adding collisions to floors in Character creator. Currently my character seems to have collision by default. He doesn't fall through the floor and has a shadow behind him. But his cape goes through the floor. If I turn the floor off, the character still has collision. What is the character walking on and can I have this surface collide with other objects. Like if I want to bounce a ball with physics, I can't because there's nothing to collide with. I've added a picture of the problem. You can see how the cap clips through the backdrop/floor I turned physics on, on the backdroup but it doesn't repel the cape. Please ignore clipping on the character, it doesn't happen during the duration of the animation and is only seen when I pause it.
Appreciate any help to solve this issue. In unity the way I do this is select the object and add collision.
By Rampa - Last Year
There is an infinite physics plane in the props folder. The quickest way to find it is: Select the Item Tab. Select the All category. Search for "infinite".
