How do I get the attached props from a parent?
https://forum.reallusion.com/Topic548695.aspx
Print Topic | Close Window
By Kelleytoons - 2 Years Ago
So... I thought I knew this, but apparently either I've forgotten or I've never known.
When I get an avatar I get ALL the mesh names of the clothing and even props attached to it with:
mesh_list = avatar.GetMeshNames()
but this does not work for a prop, which if it had attached children and I:
mesh_list = prop.GetMeshNames()
only gives me the parent props mesh names.
Is there no way to do this?  I searched the API (both 7 and 8) and found only mentions in passing of how they might have had some references to prop's children but no actual language on how to do it.
By Victor.Soupday - 2 Years Ago
I've been dealing with props recently for the datalink to Blender:
This is what I use to find all the attached lights, camera's, props, clothing, accessories and hair to an avatar or prop
attached = RScene.FindChildObjects(object,
                                    EObjectType_Light |
                                    EObjectType_Camera |
                                    EObjectType_Prop |
                                    EObjectType_Cloth |
                                    EObjectType_Accessory |
                                    EObjectType_Hair)
It seems to be recursive so it will also find sub props of sub props.
Thanks for replying, Victor, but that doesn't seem to be working for me (so I suspect I'm doing something wrong).
I'm calling it as:
prop_name = "Car Body"
other_props = RLPy.RScene.FindChildObjects(prop_name, RLPy.EObjectType_Prop)
but it throws an error in FindChildObjects, even though that prop exists and has lots of children.  Any clue as to what I'm not doing right?
FindChildObjects is called with the prop object itself, not it's name. So it would be:
prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, prop_name)
other_props = RLPy.RScene.FindChildObjects(prop, RLPy.EObjectType_Prop)
Thanks, Victor - I could have sworn I called it that way the first time (and when I couldn't get it to work I changed it to name) but apparently I did not for it all works now.
