Daz Gen 9 import into CC4: Eyes Import Problem
https://forum.reallusion.com/Topic548690.aspx
Print Topic | Close Window
By allex.semenovv2 - 2 Years Ago
Hi guys,
I'm sorry if this question has been asked many times before, and would gladly appreciate a link to the solution in such case, since I tried searching for this specific issue and couldn't find anything that could actually work.
I have a DAZ model (P3D Gigi, to be precise: https://www.daz3d.com/p3d-gigi-hd-for-genesis-9).
I put in the eyes in the DAZ studio, then exported the model as .fbx:
https://forum.reallusion.com/uploads/images/0b667e91-2f5d-4d68-8e0b-011a.png
Then, I tried importing the model in several ways:
1. I tried using transformer for CC3+ model which ended up with me having the following error: Failed to Load Character: No suitable Setup Profile Found.
2. Drag-n-dropping the .fbx file directly. This worked better since I can transfer and even rig the model correctly, except that the eyes look like this:
https://forum.reallusion.com/uploads/images/734250d5-e0bd-465b-bc21-1984.png
I would gladly appreciate any advice on how to possibly fix that.
Thank you!
By Peter (RL) - 2 Years Ago
Hi...
For the white eye issues, you should be able to correct this on the Material tab of the Modify Panel. Just select EyeMoisture_Right, EyeMoisture_Left and Tear and reduce the Opacity level for each one. This normally resolves the problem.
I know my question was quite basic, but this was a literal life-saving thing. Thank you so SO much!!!
