CC Scattering (SSS) in unreal engine 5
https://forum.reallusion.com/Topic548573.aspx
Print Topic | Close Window
By hamercado - 2 Years Ago
Hello
I have noticed that some wierd looking shadows appear on my CC characters when I turn on the transmission on the light as I understand it is needed to have the scattering effect for SSS materials however the scattering in the CC shader seems to work fine without the transmision active on the light.
Do I need to adjust something else to fix the weird shadow or the scattering implementation on the CC shader does not require the transmision active on the lights?
By 3DChick - 2 Years Ago
You may have already found a fix for this, but I made this video last year on SSS issues in Unreal with CC characters. Note: It changes depending on your version of Unreal, too, but this shows you what all the variables are so you know what to tweak and play with.
