Animations sometimes combine?
https://forum.reallusion.com/Topic548376.aspx
Print Topic | Close Window
By jungle_jim - 2 Years Ago
Is this a bug or a feature I don't understand? Sometimes when I change the animation it adds it after the previous animation, other times it just replaces it.
I also have problems with looping animations, it seems like it uses the amount of frames from the previous animation or something. For instance, the character takes a few steps, then the animation should loop, but it just freezes in place while the facial animations continue playing. Am I missing something?
By Peter (RL) - 2 Years Ago
Hi...
Character Creator doesn't have a user accessible timeline like iClone so you can't add multiple animations or move animations along the timeline.
For most motion clips you will normally find that adding a new one replaces the previous one, but occasionally, depending on the type and length of the motion clip, you may find one clip plays and then goes into the previous clip. To stop this just use the Remove button on the Play Bar controls to remove all animation. Then apply the motion you want.
