By Sp3c1alk - 2 Years Ago
I am beyond frustrated. I purchased the iclone plugin, hoping to be able to add effects to mesh. I download the 50 fx, the plug in, etc. I add an effect. I try to use the dropper to add it to a character, but it says I need the plugin???!!! I have the plugin snd the sequencer. What do I not have???
By mtakerkart - 2 Years Ago
Do you have this ?
Yes and no...
By wires - 2 Years Ago
Open the Reallusion Hub and under Plugin make sure that the PopcornFX plugin is tagged as installed, if not then install it from there.
Yes , as Gerry said , it seems that the PopcornFX plugin is not installed.
Marc
https://marketplace.reallusion.com/iclone/author/Takerk'ART
Thank you both, that worked. Now.... How can I make lightning crawl up a character?....
By James_Jameson - 2 Years Ago
Thanks so much for this! I spent nearly 2 hours trying everything and searching everywhere till I found you reply and realized I just needed to click on iClone in the Reallusion Hub. I was selected on CC4 so not seeing it!
