NVIDIA Audio2Face Plugin Not showing in iClone7 Plugins Menu after installation
https://forum.reallusion.com/Topic548048.aspx
Print Topic | Close Window
By lnickers_724359 - 2 Years Ago
Hello,
NVIDIA Audio2Face Plugin Not showing in iClone7 Plugins Menu after installation.
In the console i see the following error after re-launching iClone:
<class 'ImportError'>, File: C:\Users\nickarthur\AppData\Local\ov\pkg\usdview-0.22.8\pip-packages\shiboken2\files.dir\shibokensupport\__feature__.py, Line: 142
Is it possible that the iClone 7.93 application is impacted by the PYTHONPATH or PATH etc.  on my develoment machine?
Is there an obvious fix?
Thanks,
Nick
By Peter (RL) - 2 Years Ago
Hi Nick
Did you ensure that you downloaded the iClone 7 version and not the iClone 8 version?
If you did download the iClone 7 version, just double check the installation instructions below.
How to Install - for iClone 7:
Required software:
Character Creator 3.43 or above
iClone 7.93 or above
Omniverse Audio2Face 2021.3.1 or above
Unzip the downloaded plug-in file.
Copy "Omniverse_Audio2Face" folder into the iClone install directory > "C:\Program Files\Reallusion\iClone 8\Bin64\OpenPlugin\"
Once you've installed this plugin, please reopen iClone, and access it from: Plugins > Omniverse Audio2Face > Import Omniverse Audio2Face.
By blkmsk - 2 Years Ago
Hello
EDIT: its working. I copied the wrong folder, my bad!
I'm also having trouble setting up the AudioToFace Plugin but in iClone 8.
I downloaded the zip, copied the 'NVIDIA_Audio2Face_for_iClone_8' folder to 'C:\Program Files\Reallusion\iClone 8\Bin64\OpenPlugin'
but the plugin is not showing in the plugin menu.
Cheers
Ben
