Mesh to Head suddenly stopped working
https://forum.reallusion.com/Topic547755.aspx
Print Topic | Close Window
By mudboxguru - 9 Months Ago
I had just used the mesh to head feature on the same model about two hours ago and it had worked fine. Now every time I try to do mesh to head CC4 says: Failed to record undo/redo step. Undo manager will restart. Then CC4 closes without error.
By Peter (RL) - 9 Months Ago
Please try closing down CC4 and restart your computer. Then try again.
If the problem persists, please check how much free space you have on the C: drive? By default temporary files are saved to the C: drive so the error may indicate you have run out of space for the temporary files needed to undo.
