Affinity Designer 2 problem
https://forum.reallusion.com/Topic547633.aspx
Print Topic | Close Window
By teknology3d - 2 Years Ago
Hello guys. I setup affinity designer 2 for from wit CA5 but seems is not opening from the menu, I ean I calle the program within CA5 even I set everything properly. The same happens with affinity photo 2. Anyone can explain if having the same issue? Thanks
By Sophus - 2 Years Ago
I think you need to install Affinity V2 products via the EXE (MSI)-installers. If you use the MSIX-installers the Affinity software gets sandboxed by Windows security systems. That's what Microsoft wants, but then you cannot integrate it as an external editor into programs like CA5. Since there were a lot of complaints, Affinity added additional installers a while back.
Oh! I didn't know. Thank you so much. i will try later. Great day!!
