Iclone 7.9 timeline " by frame" (slow motion) via iclone live kink to ue 5.3.2 and how to fix slowmotion to normal speed .
https://forum.reallusion.com/Topic547574.aspx
Print Topic | Close Window
By chrispnpro - 2 Years Ago
Hi!
Ive just tested the "by frame" function in iclone 7.9 timeline  due to i earlier got some framedrops in take recorder ..
The by frame works great but as it is recorded  in take recorder  in slow motion I don knew how to  fix the  sequence into normal speed..
https://forum.reallusion.com/uploads/images/dc46441a-b47f-4d88-9fbb-7b8d.jpg
https://forum.reallusion.com/uploads/images/43ba09c5-96e1-4c64-b261-24b3.jpg
https://forum.reallusion.com/uploads/images/56bfdcc4-799b-4344-ada6-2131.jpg
By StyleMarshal - 2 Years Ago
1. Double click on the recorded animation and change the "Rate Scale" and save ...
https://forum.reallusion.com/uploads/images/fca359c5-6871-4b56-8d9a-8726.jpg
2. Or in Sequencer right click on the animation track and change the "Play Rate"  :
https://forum.reallusion.com/uploads/images/906e989c-dcce-4976-b311-e3ef.jpg
Thankyou Bassline !
I double clicked on the recorded animation and changed the rate scale from 1 to 2.  It seems a little bit to fast but i will figure it out .
Usually when i playback the sequence in take recorder i uncheck " use live link body " and there is no feetslip.
But now the feetslip is there !
I reopened the org sequence and now in sequenzer i rightklick and changed the playrate for body  face   feet  legs and torso to 2 but the feet slip is still there.
You can use comma like 1.5 ...
does your feet slip or your root motion ?
Can you show a short video ?
With IClone 8 you can use timecode when recording with take recorder.
So with IC7.9 I would suggest to export and import the animation via FBX ( best quality and original speed )
Yes i changed rate scale to 1,7 seems better.
https://forum.reallusion.com/uploads/images/e417310d-aa1f-4fdf-9067-e5fc.jpg
Untitled 8 - YouTube       it doesnt look like feet slip please ck the video   Untitled 8 - YouTube
Regarding timecode and sync in iclone 8 looks very good...but its to much money for me to upgrade so fbx  export to ue looks fine and i will start to ck tutorials and see if i can handle it
It looks very good...https://www.youtube.com/watch?v=Mgy0jbe8ig4
Oh you are using Meta Humans. Yes , root motion , when you record with Take Recoder it records the location transform keys of the root too and this track is missing now.
You should bake the whole animation into one track before you change the speed....
But it can be so easy when using import and export , have a look :
Thanks a lot Bassline...it works  but the mh is maybee to tall :-)  M_med_nrw
https://youtu.be/DCDeoB0uuH0
chrispnpro (2/15/2024)
have a look 😁 :
Thankyou very much Bassline.
The mh had the wrong dna he was incoperated with a  female dna but now i changed to m_med_mrw with subject Cooper and he looks ok :-)
https://forum.reallusion.com/uploads/images/d8d717f3-ea7f-4b47-a4cd-8074.jpg
