prepurchase question
https://forum.reallusion.com/Topic546667.aspx
Print Topic | Close Window
By info.right2freedom - 2 Years Ago
Can I create in cartoon animator the same kind of actors that I can create in Crazytalk 8? I know that the animator is much superior and I saw that the CT8 is discontinued, so I am wandering is all the features CT8 had are available in CTA?
Can I also do 2d and 3d actor faces in great detail? Also is exist some motion clips and auto motions as CT8 have? Or could somebody list me what I can not do in CTA what I was able to do in CT8?
also some additional question, because I am not familiar with CTA
1. Can I just replace the texture of an existing actor, example I have a white cat and I want to replace it with a black cat which is same, except the color?
2. Can I upload a video to my timeline?
3. Can I export transparent video?
By Peter (RL) - 2 Years Ago
info.right2freedom (1/23/2024)
Yes. Cartoon Animator 5 allows you to create talking characters from photos or drawings just as CrazyTalk did previously. The creation process is very similar overall. Facial animation can be created within CTA5 for photo based characters, and a number of animations are included for use with the included G3 characters.
If the character or prop is SVG (Vector) based then you can adjust the color within CTA5 using the SVG Color Adjustment feature. If the character or prop is Bitmap (Raster) based then you will normally need to send the character or prop to an image editor to change the color.
Videos can be dragged into the viewport and used as a prop where they will show up on the Timeline.
Yes you can use .MOV format, Sequence Image or popVideo.
