how to save custom eyebrow with all the adjustments I have made
Home
Character Creator 4
Technical Issues
https://forum.reallusion.com/Topic546282.aspx
Print Topic
Close Window
By Duude
Last Year
So basically I have created this perfect eyebrow shape, but I don't know how to save the eyebrow with all the custom adjustments I have made. I know I can save it as png, but I want to save it as skingen preset so I get the form correctly when I then use it on another character. I also have made like this black make up eye liner on top of it to give that modern day thick eyebrow look. If I can save the eyebrow as skingen preset then I don't need to readjust the size to fit on another character so uisng skingen preset would be very nice thing to have.
So far haven't found how to do this so if there's away I would much appreciate it :)
By 4u2ges
Last Year
I assume you customized an eyebrow applied as skin-gen layer in makeup.
While the eyebrow layer is selected in AE, go to Content > Makeup > Eyebrow and click Save.
By Duude
Last Year
I don't understand what you mean. Do you mean I save the eyebrow as png file ? That I know how t o do, but isn't what I asked for.
I need to save new skingen eyebrow preset that includes all the resizing and coloring I did. what you mean by AE selected in AE ? Appearance editor ?
By rosuckmedia
Last Year
Hi Duude
I only changed the eyebrow with Edit Mesh.Test
Then I saved them Custom Hair Element.
Maybe this will help you.
Greetings Robert
By Duude
Last Year
rosuckmedia (1/15/2024)
Hi Duude
Greetings Robert
Yes I got it to work now.
I concluded from your photo that I need to have the custom hair element open and that it has to be saved from the content window from "save" like you highlighted. Whne I push the save I did I had the option to choose what element I can save and there the eyebrow was among all other things under makeup. It saved the preset just like normal sking gen preset and it works! Thanks
I assume that acording to the element I save they are automatically moved into right folder ? Like this eyebro wnet into custom hair element.
