By tegnemaskin - 2 Years Ago
Hey all, I have imported my image maps into the right channels it seems, but not sure if the emission map have any strength at all. On his lower arm there should be a couple of emissive leds. The map is, as I am used to, black except those areas that are supposed to glow. Is this the right way of doing this or am I missing out on some settings? Thanks!
By Peter (RL) - 2 Years Ago
Hi...
The problem is all your maps are too dark to generate a good glow effect. Generally light colors give the best glow effects, dark colors the worst.
Please see the section on Glow Maps below. This explains what you need to do.
https://manual.reallusion.com/Character-Creator-4/Content/ENU/4.0/15_Multiple_Channel_Texture_Mapping/Types_of_maps_PBR.htm
Thank you - that did the trick!
