By surachit.songcharoen - Last Year
Hi there, has there been a solution for merge material crash yet? Every time I export rather complex character (eg. char with full cloth) using merge material option the export progress always stops at around 72%, while simple characters can be exported using this option without any issue. Trying to search for solution online but there is no real solution to this.
Thanks.
By Peter (RL) - Last Year
Hi...
Sorry to hear you are having these crashing issues.
Did you report the problem in the Feedback Tracker? If yes, then you should have received a status update on the issue there. If you haven't yet reported it, please do so and the dev team will investigate. The Feedback Tracker is the best way to get issues looked at and fixed.
And do remember that for issues seriously affecting your use of the software, you can contact Technical Support using the link below. They will then try to help you.
