By ImmersiveR - 2 Years Ago
Hi, I am creating this post to provide advice on using the CC/iC Importer URP 1.4.7 package.
I noticed sometimes when trying to create an animation controller for an imported character, it would not generate. It turns out, if you import a character and untick the Import Animation box, or remove the default T-Pose animation clip, a controller can't be generated. I didn't realise this was an issue because there is no mention of this anywhere in terms of documentation or editor warnings etc,. It seems like a logical step to remove unused T-Pose clips or just untick the Import Animation box, as the T-Pose is likely no use.
Enable the Import Animation box and Add the default clip to enable generation. I find it slightly baffling that there isn't an editor warning for this.
Thanks
