By peteradam6 - 14 Years Ago
How can I export a 3D Warehouse model as an accessory rather than a prop, in 3Dxchange 4? I choose the accessory folder to export to, but then I just get .iProps in there.
And, just for future reference, how can I export things like .iShoe?
By Seeker769 - 14 Years Ago
I'm not 100% sure, but I don't think you can convert props to accessories in 3DX4. You can however import the prop into iClone and attach it to a character ( link may also work ) set it at the position you want, then save it. iClone will automatically convert it to an accessory and place it in the relevant folder. As for exporting iProps, I think you can only export as obj. even with the pro version.
By animagic - 14 Years Ago
peteradam6 (6/25/2010) And, just for future reference, how can I export things like .iShoe?I don't think you can do that but that would indeed be useful. For example, the shoes I have are too perfect and need some beating up (without having to use 3D Max...) Maybe a feature request?
By Peter (RL) - 14 Years Ago
You can just rename an iAcc to iProp, then open it in 3DXchange4 to make changes. Then export it from 3DXchange4 as an iProp, rename it to iAcc and import into iClone4. You will need to attach it, then reposition it and finally resave it as a new custom accessory. If you are working with a model from the Google Warehouse or Sketchup, just start at step 2.
zuijlen (6/25/2010)
peteradam6 (6/25/2010) And, just for future reference, how can I export things like .iShoe?I don't think you can do that but that would indeed be useful. For example, the shoes I have are too perfect and need some beating up (without having to use 3D Max...) Maybe a feature request? For shoes you can do the following: 1) Add your shoes to any avatar and then open it up in 3DXchange4. 2) Then export just the shoes to OBJ, make the required changes, then reload back in 3DX4. 3) Then export the avatar, open in iClone4 and resave your new edited shoes to the library.
Thanks, Peter! I'm going to try that this weekend. See, there are a lot of helpful people on this forum!
By warlord720 - 14 Years Ago
Great info Peter. Thanks!
@sw00000p, I haven't done much with AML and I can only answer questions if I know something about the subject and I know very little about AML. The AML Editor that was supposed to make things easier no longer works in IC4. Did you see the AML Wiki (at http://www.iclonewiki.com)? It looks to be extensive documentation beyond the basic tutorial.
By RenSpur - 9 Years Ago
I found out the hard way, when I decided to make the DAZ character "Freak" a main character in my movie "Forgotten Plan 8 of the ASA." I picked "Freak" to be the actor for my character "Big Daddy Dirnsa" only to find out the mobility limitations of a non-standard DAZ character. I setup "Big Daddy Dirnsa" by changing all the skin but the hands and face to glossy black. I added hair and boots to set off the ensemble. When I exported/imported to iClone (3DX) I found out when I tried to make "Big Daddy" move his hair and boots did not follow his movements. I exported another iteration of "Big Daddy" from DAZ with the hair and boots. I exported/imported the hair and boots separately. I found the hair, once imported into iClone, was way too small and even sizing all the dimensions out to 9999 did not make the hair big enough to totally fit "Big Daddy's" head. After wasting much time trying to change the size of the hair I gave up and decided to try a work around. I used four iterations of the hair to blend "Big Daddy's" hair (front, back, left and right). Once fitted I attached all four, to the head, and it actually came out better than the single hairpiece. I was quite satisfied with the work around. I thought perhaps I could do something similar with the boots but all my attempts were a total failure. I am going to try the "Tutor's" suggestions. However, I wanted to complete the project so I put props in the foreground to hide "Big Daddy's" feet. If I continue to use "Big Daddy," as part of a series, I will have to first resolve the boots problem. I am more into making videos than all the technical aspects. It looks like most RL users are 3D nerds. Nothing wrong with that just not my bag. Then again perhaps go on too much. Thanks for listening. Colonel Fannin aka "RenSpur."
By Rampa - 9 Years Ago
Here's a tutorial that might help. If your using Genesis 1, use the appropriate DUF and t-pose.
If your using a pre Genesis version of the Freak, it gets a bit more tricky, especially the visemes (mouth shapes for speaking).
By animagic - 9 Years Ago
There is an iClone DAZ Freak starter bundle that has the Freak character already converted to a non-standard iClone character. The pack is here: http://www.reallusion.com/ContentStore/iclone/pack/Daz_Freak5/default.aspx.
I don't know if that would make things easier.
Thank you Tutor. I solved the boots problem by starting with the boots then adding the character to the scene in DAZ. I then fitted the character to the boots. Backward but worked great! The imported "Freak 5" character now can perform leg motions without the boots floating off into outer space. Although I successfully navigated the operation I was not able to duplicate it. I do not consider I have "learned" anything unless I can duplicate the procedure. So before I can proclaim mastery of the process I will have to duplicate it (and record it) more.
Thank you, thank you very much. I did not state I was using iClone 6.
I did encounter another problem. I did not add clothes but changed all the skin (except head and hands) to chrome. I then changed all the chrome surfaces to black (7 degrees above zero). However, when I imported from 3DX the skin was chrome. I did another work-around by changing the chrome to black in 3DX. This worked fine and I got a black chrome effect which is what I wanted. My question is how do I export from DAZ to 3DX with the DAZ surfaces parameters being visible in 3DX? As a "newbie" I did not find a black chrome setting.
