The accuface window is too small under 4k resolution monitor
https://forum.reallusion.com/Topic544177.aspx
Print Topic | Close Window
By MOTO4G - 2 Years Ago
https://forum.reallusion.com/uploads/images/ab9977b1-812e-4294-8f6c-5b1c.pngthe words are too small to read under 4k resolution, please fix it
By Peter (RL) - 2 Years Ago
Please try the following to see if it helps.
1. Go into your iClone Preferences (CTRL+P) and set the Icon and Font size to the largest of the available sizes.
If that doesn't help, try the following with iClone closed down:
2. In Windows File Explorer find your iClone.exe file which by default will be in the folder below.
C:\Program Files\Reallusion\iClone 8\Bin64\iClone.exe
3. Right click iClone.exe and select Properties the click the Compatibility tab.
4. Now click on "Change High DPI Settings" and then change the "Override High DPI Scaling Behaviour" dropdown to System.
5. Finally click OK and then OK again to close Properties down.
6. Launch iClone again and check if the issue is resolved or better.
