By ExE Production - 3 Years Ago
Hey yall, I've ran into a strange issue when i have the headshot 2 plugin installed. I had reinstalled all of my software and reinstalled and have been getting the same issue. I wanted to see if anyone else has ran into this problem as well. So far i have uninstalled Head shot when im not using it and reinstalling it to create the create i need before uninstalling it to keep going forward.
No HeadShot Installed
HeadShot Installed
FeedBack Tracker : https://www.reallusion.com/FeedBackTracker/Issue/90-frame-drop-with-Headshot-2-0-plugin-installed
I guess imma close this one up I might be the only one having this problem. I found uninstalling head shot 1 helped reducing the lag if anyone comes across this with the same problem. Removing head shot completely solves it.
By Peter (RL) - 3 Years Ago
As you have found it is not recommended to have Headshot 1 and Headshot 2 installed at the same time. All the features of Headshot 1 are included in version 2 so that is the only version you need.
By animagic - 3 Years Ago
There is one caveat though, and that is that Headshot 2 does not recognize heads made with Headshot 1, so you are not able to modify those heads further.
At least, that has been my experience. I don't know if that is a limitation or a bug...:unsure:
By dma.surrey - 2 Years Ago
I have the same issue and for me it is not lagging when only headshot 1 is intsalled just headshot 2 is casuing the lag for me. Idk why and weirdly when headshot 2 is installed the gpu usage is 0% when the app is in fullscreen and if I press start button the lag fixes until unless i dont press anywhere on the app again and once I come back and click on app it starts lagging again. It is a problem where headshot 2 stops cc4 from using gpu. Please fix these reallusion.
